What is HDMI switching????
im not positive, but a google search gave some insight.
i think it is just the ability to switch between two HDMI sources. like if you have an HDMI DVD player and an HDMI digital source going into your unit, it can switch between the two sources. again, this is my guess...
my conclusion as to whether or not you need it, i would say absolutly not. you can always run component video and opti audio in lieu of HDMI.
then you definitly dont need it...
and FYI, you do not have to have HDMI to have HD. the HDMI cables are quite expensive, and as far as i know, have no advantage over component vid and optical. but if you choose to go that route, you def dont need switching, just go from PS3 to reciever, reciever to TV
no prob //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i didnt think about 1080p, im not sure as to whether or not HDMI is required for that... i know for up to 1080I it isnt though, and i have been told that 1080I and 1080P is nearly indistinguishable. 1080i looks killer though, so enjoy it when ya get it all hooked up //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i dug a little deeper and got a few more answers in case you or others needed it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
it looks like an HDMI cable IS required to deliver a 1080p signal. however, on the PS3's, they do NOT require an HDMI to output in 1080p yet. i guess there is going to be some add on to the ps3 to allow it to output in a true 1080p format.
hdmi audio on blu ray and hd-dvd sounds a whole lot better then optical... due to higher bit rates
also in my setup hdmi sounds better then analog 5.1 outputs
Pistonsfan70
Pistonsfan70
Detroit Area, MI
1loudsuv
