what is BL?
This is a measurement of the motor strength of a speaker. A high BL figure indicates a very strong transducer that moves the cone with authority.
yes, more motor strength is better
for comparison: (all 15")
XXX:17.1
Magnum: 21.5
Brahma: 15.9
Death Penalty: 26.591
You can have too much motor strength, just like you can have too little. You want enough motor strength to accomplish your design goals, and no more. No less, either...
Dan Wiggins
Adire Audio
BL is the mechanical force created by the woofer, and it can be defined as B x L. where L represents the length of wire on the coil, and B represents the given flux density, or magnetic capabilities of the wire used.
and as Mr. Wiggins pointed out, there can be such a thing as too much Bl. but typically, more Bl leads to better cone control and excursion capabilities, all of which leave the picture once the coil leaves the gap though...
well brahmas have low BL compared to the rest listed. does that mean less SPL? Dan Wiggins how do u think brahmas compare to the other 3 subs in SPL potential?
Scottie Johnson set quite a few records with Brahmas. Tempests have a BL of 14.2, and Marshall Joyner just won World Finals MR2 for MECA.
In other words, BL is not a guideline in terms of SPL... SPL is about displacement. The driver with the most stroke for the applied power wins. Period. You want the motor to be strong enough to reach full excursion with the power you have available in the box you're running, if you want full-on SPL. If you can do it with a BL or 10, then any BL above that level isn't really needed.
No, doesn't really mean anything for cone control at all. It does mean less power required for a given excursion level (all else being equal); however, it also means less bass. If you get your BL from lots of extra L, then you increase mass, and lose your efficiency gain. And having a really high BL means you generate a lot of back EMF, so you have higher impedance swings (really only an issue with tube amps).
Dan Wiggins
Adire Audio
thanks for explaining that, im still trying to learn it all, as you can probably tell ive got some of the basic principles... just havent learned the applications. when i said cone control i meant the excursion levels... i just didnt word it right //content.invisioncic.com/y282845/emoticons/spank.gif.0d78e34d42ea8780359e903aeb6697d6.gif
sound giant
sound giant
Aiea, Oahu, Hawaii
hoss
michigan born
    May 14, 2026
michigan born
    May 14, 2026
