WHAT?? i need help
ok new problem , its been doing this for a little bit, my amp is making a whirling wizzing sound . as i accelerate it get higher and it also picks up sounds like when i hit the turn signal, the subs click with it. how do i stop this
it's called ground loop.
reground your amp/s to BARE METAL. if you have multiple amps, ground them to one spot. also ground your hu to the chassis/frame of the car as well as the amps (if it's bolted to a body panel or a seat bracket).
also disconnect your rcas and see if it's the amp or hu.
maybe run a ground from your hu to the battery.
ballisticBaller
ballisticBaller
MO
ballisticBaller
