yamaman
Hey there I was just wandering what everyone uses to mount your subs to you mdf rings or sub box. I want sometihng that is going to be stronger then just screws so I can actaully tighten the sub down. I have an idea what I want to use but I can not remember the name of them. What they are is a peice of metal that has a meta plate on the back then a threaded tube that will go up through a hole that will be drilled thought the mdf and then the second part is like a bolt that will thread into this other peice so It will be metal threading into metal and there will be a greater surface area to distribute the pressure on the mdf. anyway if anyone knows what I am talking about can you tell me what they are and maybe a pic would be nice too. or else what do you use???? Thanx for reading this long bugger. lata
