what does a H/O alt really do
tjjohnson91
what it states when i start my car and run it at 14.6V and my system hit it goes down to 13.5 right, does the alt stop the drop of the volts ? and why do people say i should buy more batterys when they are at 12V........... the souce of the power is the alt what the hell
im looking to run a AP3000d to two memphis mojo 15's...... i have one 116ah battery and a starting battery.
if i really want i only turn the amp about half way it drops the volt to 12.9 when reving the ****er up
so my Q is does it stop the volts for dropping even
As said, it only produces more current to charge your batteries and supply demand.
Before you do anything do the Big 3 (search it) and upgrade your battery under the hood. If you are still having trouble with voltage drop add another battery in the trunk, and if you still have issues a HO alt is a good consideration.
this....
BTW you should probably add another battery in the back if your going to run that ap30001d
tjjohnson91
tjjohnson91
welcome mn
Deeper_shades
