What do you use?
thanks guys, was workin on my box tonight and after messin up a couple cuts i quit. i'll pick up some 2x4s tommrow and give that a try. Here i thought i was just terrible at it. Wish i could afford a table saw:crap:
i usualy get my wood pre-cut at home depot. i do the measurments myself then tell them to cut.
What's the fun in that?//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif That would be nice, don't think theres a home depot around here, and i had to do some searching for myself at menards, guy i talked to didn't know what MDF was.
Black and decker...thats my $20 jig saw haha. By the time im done spending money on materials and tools i might as well have had someone biuld the box for me.//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif good thing i'll never stop changing my setup...so eventually it will pay off.
there's any easy way to make a fence/jig:
Get a 2x4 and glue/screw it into a piece of 1/4" or 1/2" plywood or MDF, leaving a free end of just MDF that is about the width of the saw's boot. Then clamp down the sheet of wood and with the saw calibrated/aligned properly, rip down the sheet along the 2x4. Do the same thing on the other side, but cut along the other side of the boot (the narrower side). Now you can easily line up the fence with your cutting line since the blade will cut exactly where the edge of the MDF or plywood sheet is, and you can use either side of the boot to line it up.
I normally cut off a small slither of the longest piece and use the straight edge as my guide... but, I don't have them fancy schmancy C clamps. I use the good ol' "Push up against the wall" technique... AKA push the flat end against the wall and run the saw against it. This requires two people. (One to hold/push the wood, the other to run the saw. Most of my cuts are straight (main word: MOST). I still put a nice cover of silicone around the edges just incase.
But, as someone said before, Home Depot cuts if you buy the wood from them. At least here they do. And they're surprisingly straight... it makes life easier; no stress cutting it and easier to move. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
I don't know if they do angled cuts, though. That'd be pretty raw. I wouldn't shop anywhere else. Even if they only had 1/2" MDF
Make a guide.. Very easy. measure the distance you need, then measure the distance from the edge of the blade to the edge of the saw, put a 2x4 there and go. Your cuts will be prefect.
both home depot and lowes told me to go away today LOL.. Was hoping to get a sheet cut and one guy looked at me like I had 3 arms or something!!
This is what I showed him, and from the look on his face, I think he was looking at pland to build a spaceship or something. Looks pretty self explanitory to me... And I know they cant make the smaller cuts, but making most of the cuts would save me a lot of time and crawling around!!
ill probably just use some of my scrap mdf like a long peice that still has a factory edge, use my clamps that i have...not c clamps but they shud work i think, i'll report back.....with pics?
bumpinaintEZ
pontiac supporter
bumpinaintEZ
Spearfish
ThatChevyGuy
