What do you use to seal.
Bartak1
Ok, I need to know what you guys suggest for sealing a box. On my last one I used a hot glue gun and I think it worked alright. Could I do this again or should I use something else? Will regular silicone work? or what about liquid nails.
Also, Any ideas on what to use to seal where the sub meets the box. Would felt work?
Thanks.
I use silicone caulking, its cheap and works. In a pinch ive used liquid nails and it worked fine but I like using silicone caulking better. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
How is liquid nails useless? I use it in place of wood glue, and it works like a charm.
IMO = In my opinion //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
1 gallon of Tite bond is far cheaper than a bunch of tubes of LN...I also find it irritating re-using a tube of LN...
Use wood glue instead of liquid nails because it is forms a chemical bond rather than a surface bond like liquid nails does. Thats what I use then caulk all the seams with silicone and its airtight.
i use wood glue for the buildin process... then i throw on liquid nails on the inside of all the seams.... it only cost me 1.92 for a tue of liquid nails where i live, plus with my emplyee discount at ace... but i think that using Liquid nails for holdin the box together is pointless becuz like btnhfan said above, it only forms a surface bond to the materials its touching... so its pointless having a bond on the surface when the glue acts as wood itself...
Bartak1
Bartak1
Nebraska
Bartak1
