What do you use for ports?
if your going to use pvc, forget about the flares. the flares are around 4.125'' od where pvc is 4.5''. if you want to use aeros and need longer than the 17'' that the parts express kit can do, then buy the flare kit from precision port and get the 15 3/4'' tube that pe carrys from dayton audio.
schedule 40 will have an inner diameter that is too small, 35 works better, you can also look into cardboard tubes if you arnt going to throw crazy power to your setup. Or even coat them in resin for strength
the id of 4'' schedule 40 is 3.998 //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
45js45
45js45
lost.....again
pro-rabbit
