What do you think?
packer57
17
GF
Is this any good?
Lightning Audio® Turbo-Charged Bass Kit
Check Out this Powerful Package from Lightning Audio®
Includes a 450-watt max power amplifier and two 10” subwoofers with rubber surround, fully loaded and wired in the sub box.
Model: FF210.150 For $219.00
System includes a rugged sub box, pre-loaded with subwoofer drivers and a performance-matched amp
Amp delivers 450W peak, 150W RMS (continuous) @ 4 ohms, bridged; 75W RMS x 2 @ 2 ohms; 50W RMS x 2 @ 4 ohms
40-400Hz variable crossover lets you dial in just the right thump
Switchable Juice Boost bass EQ (+6dB)
Line- and speaker-level inputs integrate with virtually any car stereo
Dual 10" woofers handle up to 750W peak, 150W RMS @ 4 ohms
Polypropylene cones with foam surrounds
1.5" four-layer copper voice coil
They also have one with 12' subs and amp 750w for 299.00
Amp delivers 700W peak @ 4 ohms; 250W RMS (continuous) x 1 @ 2 ohms; 150W RMS x 1 @ 4 ohms
1-ohm stable power supply
40-130Hz variable crossover lets you dial in just the right thump
Variable Juice Boost bass EQ (0-12dB)
Remote level control
Dual 12" woofers handle up to 750W peak, 150W RMS @ 4 ohms
1.5" four-layer copper voice coils
ur going to put it in, like it for an hour, then realize how much cash you just wasted. i was in the same position about 6 months ago (i asked about the same package cept not F&F), then I came here.
If you're on a tight budget, I suggest Kicker Comp VRs or Pioneer Premier something cant remember the model #'s. Also, BUY ONLINE!! you will save unbelievable amounts of money if you buy things off sites/ebay.
Originally posted by packer57 Less then 400.00. But if i get this i can always upgrade later.
man listen to them. if you want a decent system you are literally throwing your money away. if your budget is four hundred you can do alot better.
example: 2 comp vr 12's from ike sound- 180 shipped
jbl 300, us acoustics or any solid amp for around $150
a custom box from on of the guys on the forum around $70. maybe more.
or just get one twelve, a bigger amp and a bigger box.
well pick out all the equipment that your going to buy and then when the time comes to install it....PM me or email me and i will walk you through it.
packer57
packer57
GF
DaBaller504
Doxquzme
    May 14, 2026
ThxOne
    May 13, 2026
