Sythlord79
Im a noob and trying to compare Subwoofers. I was wondering what each of these specs mean. Does it tell me accuracy? how much air pressure I'd feel? what do these numbers mean exactly? I was hoping to have a better sense of what the differences between subs when comparing. I just randomly picked this sub's specs as an example. Thanks!
Nominal Impedance (Znom): 4 ohm
Thermal Power Handling (Pt): 400W
Driver Displacement: 0.096 cu. ft. / 2.72 liters
Free Air Resonance (Fs): 23.66 Hz
Electrical “Q” (Qes): 0.465
Mechanical “Q” (Qms): 6.774
Total Speaker “Q” (Qts): 0.435
Equivalent Compliance (Vas): 4.793 cu. ft. / 135.74 liters
One-Way, Linear Excursion (Xmax)*: 0.610 in. / 15.5 mm
Reference Efficiency (no): 0.371%
Efficiency (1W/1m)**: 87.90 dB SPL
Effective Piston Area (Sd): 103.850 sq. in. / 0.0670 sq. m.
DC Resistance (Re): 3.569 ohm
Net Weight: 17.75 lbs. / 8.05 kg
