What distribution block?
Down
I have kind of a wierd setup, and I'm looking for a distro block that'll fit my needs. I need 1 1/0g input, 1 1/0g out, and 2 8g out. The 1/0 HAS to be a 200amp fuse, the other 2 are 60's. Having a digital readout would be nice, but I can't even find a regular one. Any suggestions?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
-Down
Maybe less than 1/0 gauge to the amp? What is the amp...how long is the run of power wire... and look into stinger stuff on E-bay stores, they have alot.
yeah they don't make a lot of 1/0 gauge input/output distros
couldn't you just run 4 gauge to it?
or you could just get some other 4 gauge and make a second run to the trunk that way you have a dedicated line of 1/0 for that amp
Yea, thats the one I have, and because of that, I have to run my Mojo at 4ohms instead of 2 //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
-Down
-Down
for the 200amp fuse just take the cases off and use 2 100amp ones
Hmmm, you can do that? Sounds interesting, so I just screw them both on in the same location, correct? Can that be done with mini anl fuses?
-Down
That is what Bill @ Knukonceptz told me to do when I wanted a bigger Mini-ANL fuse... You just need to get the covers off them down to the raw fuse and sandwich them in the same terminals.
Now I understand! Took me a while though. Thanks, that pretty much took care of my problem //content.invisioncic.com/y282845/emoticons/bowdown.gif.b85b23b82970bd22fb6b549c3392f016.gif
-Down
Down
Down
SA,TX
bubbagumper6
