What cuts a circle with precision?
gmc typhoon
ny
I just tried the rotozip with the circle cutter attachment and let's just say i can cut a better circle with my teeth.//content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif So i need a tool that can make a PERFECT circle. What should i use? I need to make the hole for my rl-i8 sub to drop in.
Thanks guys:)
i've used everything from the Jigsaw|Compass to JasperJig|Router including the RotoZip with it's circle jig.
All will work with patience and practice. The results are the same, the level of effort is different though.
router and jasper jig = precision
jigsaw + me = good enough to not tell the difference when covered
Jigsaw is more fun because it takes more skill.
hole saw, water jet, CNC machine... //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Water jet? water + mdf = very bad //content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
I left a piece outside. The thing ended up being 1.5" thick with all the water it absorbed.
My hand isn't steady enough to use a jigsaw. I use the router & jig because it's easier, faster, and the results are consistent (just as long as I do it right the first time).
gmc typhoon
gmc typhoon
ny
iamamp3pimp
NorthFramingham
    Jun 30, 2026
