What could be fun to do with an RE8?
for the extra sub however, the deal with your room would be awesome, however i would take the sub along with your other subs, amp it, and send all the signals through a crossover so you can filter out the higher bass freq. to the RE8 and the lower ones to the larger subs, this would give you a cleaner sound overall....
yeah but i wouldnt of either unless i had taken my physics class last year. The water would put a lot of pressure on the sub and it does not move like air does, when the sub hits in a sealed box, the air pressure just changes, but water doesnt change that easily.....it is much more dense than air is...
Then just use a little bit of water. That's really what I meant, I didn't mean put 20 gallons in it.
i think JackFrost had a better suggestion about why NOT to fill the box with water. This is coming from Jonahdude's sig.
by Jack Frost:
noooo...don't do that, then the squirrels that live inside and push your subwoofer in and out won't be able to breathe!
by Jack Frost:
HAHAHA thats funny! props to him!
A little bit of water would be cool, it would spike like non other too! (the water would) it might be cool but who knows how it will sound
I can't believe that ended up in Jonah's sig...although, the original context was why you should go with a ported enclosure, IIRC //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Just make a 100% plexiglass sealed enclosure, invert the RE8 and point it up, and put about 1/4" of water in the enclosure. If it's properly sealed, you have a working enclosure with some fancy water effects. Food dye adds to the fun!
loudfivepoint0
loudfivepoint0
Hot Springs, AR
Raven
