What can I get?
argenis69
SQ Bass Lover
Hello Guys, I am getting frustrated with the voltage drops and all that.
1- I want to know what's the maximum RMS in amplifier power can my alternator (200Amp alternator at idle it produces 100-125 amp and 1 xs power d3100 battery at the trunk) handle without getting those voltage drops?
2- How can I calculate this?
(If you need more details in the system, it's on my signature)
Thank you.
Thank you.
What are you dropping to?
I mean it depends on what you're running. I would say 2.5-3k would be the max range I would go to with that electrical. If you are having severe voltage drop with power at this level right now I would assume that you have a bad ground. I assume you know how to set a gain properly so just let us know what's up and we can get you where you want to be.
My voltage drops to low 12v and the thing is that my amplifiers sometimes cut off when they are at loud volumes.
Yea something is wrong ...is it shutting off or going into soft protect? I suspect incorrect set gains or a bad ground . Start there then if you still have a issue maybe time for a agm under the hood or another 3100 in back
A bad ground connection while do this that bad? How can I correctly check if the ground is good?
Since you don't have a frame rail to ground to your chassis at best is likely supporting current flow equal to a 4 awg OFC cable. Since you're having voltage drop problems I suggest adding a 1/0 awg OFC ground cable from your existing amplifier ground spot to the same place your battery up front is grounded to the body.
Anybody know the best place to do the grounds in the rear of my car(2002 Nissan Maxima)?
How can I calculate the amount of RMS amplifier power that an alternator can handle?
Anybody know the best place to do the grounds in the rear of my car(2002*Nissan*Maxima)?
How can I calculate the amount of*RMS*amplifier*power*that an alternator*can handle??
argenis69
SQ Bass Lover
argenis69
NY, USA
argenis69
