What are these? MOSFETS?
BreakDaLaw
Cavalier Killer!
what are these and how much would they cost to fix. Also what are some causes of them frying?
i think i have your old one //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif the one you sould paaco1870 or something like that idk what i did to make this happen
if you bought paaco's amp...then it used to be mine..you blew it?
send it to db-r ..he has fixed alot of my amps in the past.....does a great job to....
the fets you have circled are on the output side of the amp....
go here http://www.db-r.com/ and post some pics so chris can give you a ball park figure on how much it will cost to fix it...........tell him ampjunkie sent you......//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Idk even know what happen i was listening to it and it was playing fine then sparks and smoke came from it i turned it off competley took it home and looked under it where i have it circled it looks to be fried in that area...idk what i did i just hooked my deka up today and this happens i dont get it
Hard telling, Most common are the IRF-z44's. But just like everyone else is saying if a bank burns out there is always a reason and depending on what else they burnt with them. I have a friend that does all my amp repair work and have relied on him for years. Not somethig I would try myself.
Well i looked at everything today...it burned the postive wire going from the amp to the binding terminal...and sort of burned the binding terminal like it got to much current or something... the gains where under half way.
BreakDaLaw
Cavalier Killer!
BreakDaLaw
Altavista
BreakDaLaw
