What are the right settings for an Orion 1200d for 2 type r's??
e22s
I just got my Orion 1200d in the mail to day...i hooked them up but dont want to play it until i have the right settings....anyone know what it is? i would try and set the gains right but i dont have the materials to do so....i have (2) 12" 2005 dual 4 ohm type r's wired to the orion at 1 ohm....please, i need some help with this....im die'n to hear how it sounds....thanks for the help....
Nobody is going to answer this question for you with much accuracy. Even if they have the same amp and subs, the preamp voltage is likely different on their head unit and this would change everything when it comes to setting the gains. I will tell you that I run a 1200D and it's power protection is very good and I doubt you will blow your subs if you take a little time to set them up. Start with the gain setting on 1/3 or so and slowly turn it up in small doses. Your setup is going to sound very sweet, go ahead try it! You would almost have to try to damage those subs provided they are hooked up properly with a clean signal and all.
e22s
e22s
Antioch, ca
Parrot
