what amp?
Size 12 -inch
Impedance 3 ohms
Cone Material Aluminum
Surround Material Foam
Sealed Box Volume (cu ft) 0.77 - 1.27
Ported Box Volume (cu ft) 2.585
Port diameter (inches) 3
Port length (inches) 8.529
Free-Air No
Dual Voice Coil Yes
Sensitivity 96.4dB
Frequency Response 20 - 0.5k Hz
RMS Power Range (Watts) 50-1100
Peak Power Handling (Watts) 2200
Top Mount Depth (inches) 6 1/2
Bottom Mount Depth (inches) N/A
Cutout Diameter or Length (inches) 10 7/8
Vas (liters) 33
Fs (Hz) 31.5
Qts 0.35
Xmax (millimeters) 18
would either of these work????
1) Lanzar 2 channel 2000 watts max 2) Legacy 1600 watts max 2 channel
·2 x 500 Watts RMS at 4 Ohms 2 x 800 Watts Output
1 x 1600 Watts Bridged Output
Fully Adjustable Crossover
·2 x 1000 Watts Max at 4 Ohms
·1 x 2000 Watts Max at 4 Ohms Bridged
·2 x 800 Watts at 2 Ohms
·Electronic Crossover Network
·Bass Boost Circuit
·Bridgeable at 4 Ohms
·2 Ohms Stereo Stable
·Tri-Mode Capable
·Gold RCA Inputs
·Line Outs For Left & Right Channels.
·Power & Protection LED Indicators
·Advanced Protection Circuitry
·Soft Turn On/Off
·Remote Control Bass Booster
·Frequency Response: 15 Hz - 35 kHz
·S/N ratio: 90dB
·Dimensions: 11.5"W x 2.3"H x 19"L
Well, firstly, you shouldn't seal those subs, you probably won't like it, but if you insist on doing so, you need to send them at least 900 watts RMS each, they aren't too efficient and won't get too loud without significant power...
Save up some more money, and look at the 'bahn A18001D amp...
why shouldnt i seal them? will it be a big difference from ported? any idea where i can find the audiobahn 1800 amp cheap? thanks
Jdogg
Jdogg
syracuse
Jdogg
