what amp should i get?
Get ur electrical up no matter whT amp u choose.... then geet a amp that does 2k or so @.5 will save u a ton on amp...unless u plan on upgrading later then get the 3.5k
What amps do 2k @.5 safely, daily? Serious question. I thought most of the smaller amps (would be a 1.2k~1.5k @1ohm) had troubles handling under 1 daily.
Mylows10 running his 4480.1d@.7 daily.I ran mine @1ohm hard and heavy, and warm to the touch,running @2ohms atm till the other gets here to run ea @1ohm load
Yea the aq will be more than enough. But after rise u will be at or over 1ohm anyway....all the 3500 amps r great..but if hes got a budgrt those might b hard to obtain
Yeah the AQ would be best IMO, if he's looking for something budget.
OP, what is your budget? Have you done any electrical upgrades? Do you plan on upgrading in the future?
I'm gonna get an ho alt and do all my upgrades about tax time. $400 is most I can spend. I've looked at the lanzar optis before. Will 1 of these push these and make them sound good?
Does $400 include the HO alt or just for amp? Some alts are more than that themselves. And you may not need a bigger alt depending on what size yours is now and the total amps you will run.
Which model Opti? But here is probably your best bet: AQ2200D Amplifier
**** all that dude there's a couple zx series amps around Illinois on Craigslist cheap! Grab a 1500 or a 2500 that will push them nice
babsuhl81
babsuhl81
decatur, il
Timmy13091
