What amp is better JL jx500 or mrx m50 from alpine
  • 4
What is the voltage of your head unit's preamp? The alpine can only accept input of up to 4 volts, I'm not sure about the jl, however.
Unless you've got a 20v signal I don't see a problem. Even then "problem" would be subjective.
A 20v signal with the gain set at 4v would be like the common newb running the gain peaked with a standard 2v preamp. You just run into clipping before full volume. It's not like the input stage will burst into flames.
There's plenty of monoblocks that are legit rated a fck load more than 1200w...
142
  • Locked
326
Amp
325
juen45
juen45
Laredo, Tx
n2audio
    May 18, 2024
    May 18, 2024
