What amp for IDQ10V3.D4
Iosias
Specs
Impedance: Dual 4 ohms
Power Range:50 - 500 Watts RMS
Mounting Depth: 5.75"
Mounting Diameter: 9.60"
Sealed Enclosure Range: .55cu.ft. - 1.1cu.ft
Ported Enclosure Range: 1.0cu.ft. - 1.5cu.ft.
Re- DC Resistance: 3.35/ 6.7 Ohms
Fs- Resonant Frequency: 22.23 Hz
Qes- Electrical "Q": .490
Qms- Mechanical "Q": 1.831
Qts- Total "Q": .387
Vas- Equivalent volume: 3.10cuft (88 liters)
Xmax- One way linear: 19.0mm
Sd- Cone Area: 399.1 cm2
Splo- Sensitivity: 85dB
Power: 50-500W RMS
XMax: 17.0mm
Sealed ft3: 0.70
Ported ft3: 1.00
Im looking too stay around under 300$
I may go with a IDQ12V3.D2 - Image Dynamics 12" sub instead the 2 ohm version
Something that does 500-600w RMS at 2 ohms..
Will the sub be in a sealed or ported enclosure?
What kind of car?
Do you have any other amps or anything?
That is a good sub, btw.. I have always wanted an IDQ, I may get one some day, but I need to at least get my amps installed and basics down first.
I lost all of the links I pasted.
JL Slash 500/1 used.
The other JL 500 watt mono amps should be fine, Alpine has a couple, RF and MTX have some.
I can't really go out and recommend any Maxxsonics amps since I don't know if they are actually decent or not.. This includes Hifonics, MB Quart, AutoTek, Crunch. Apparently some are decent, some are not. Most are made in China..
Iosias
Iosias
United States
Iosias
