what am I doing wrong?
I have it on 200 AC, and I just connect the positive lead to the + and negitive to the - on the speaker terminals, I tried grounding the negitive and got the same results.. this is using a 50hz test tone. I will try to take some pics of it later
Turn the gain all the way down and go from there. Nobody should ever need the gains on the nine.1 much higher than 2/3 up unless they are using an old school HU with 500mv or less output. You are clipping the holy crap out of the amp.
35 VAC is the number you're looking for, that's slightly over 1200 watts @ 1 ohm.
And do not use the bass boost! It's not needed with 1200 clean watts.
I did turn the gains all the way down, and I set them properly.. which ended up being like 1/3 the way up.. so I am just wondering how its even possible, with clipping to put out 65 volts (no bass boost)
If you are getting a reading of 65 volts, either your equipment is faulty, or you did not properly set the gain. Please explain in detail, the method and equipment you used to set the gain.
Ape
J-Prime
Ape
Winnipeg MB
Megalomaniac
