well well what do we have here
Pretty sick setup, I was expecting higher numbers but its tuned pretty low so thats expected, I bet its still brutal on the lows. Have you clamped the amps and what are they wired to?
are all the interior corners of box 45 degreed from sheet to sheet ?
is the inside of box glassed ?
tell me about what i can't see in the box bracing ?
i would consider glassing the full inside of box if not alreay, i can get you anything fron the select products line i go direct on that ?
it will be more slippery than cow snot
i would probably get 3 each 36 square foot stinger road kill bulk pack i get direct on that to
i would consider 38 and possibly losing a bit of low end but play a 45-50 tone
i would do what i told you to with your grounds
you should see 155 on music and like **** 160 on a tone or real close man i can see that thing doing 160
you need more bracing in my opinion
i know funds are not there
but bracing- glassing- higher tuning closer to 40 , deadner, different ground route, man i can 160 on tone
i know you want lows but i see higher numbers really not to hard to get you there
havent clamped them and yes on the lows it is brutal it does its numbers at 42hz right now and semi meter friendly. raising the tuning will help also the amops have not been clamped and more than likely wont be but they are strapped and wired at 2 ohms.
box is plan jane just the rods in it no 45's or anything tuning is going to 36 in the am tomorrow i will be doing more with deadner as soon as money becomes available. the 151 is at the headrest.
i know bread is weak now
but time & effort & desire , you know man you just started this set up
you will definetly get there
sick start bro i am real excited for you
tuning won't cost , drilling and grounding won't cost , glassing will really help ,start there little by little
long trips all start with a 1st step, and each little stride puts you closer
beautiful equipment
what is voltage out on the head unit
a few completed projects each week and by years end i really see 160 on tone
dbeez
dbeez
crestwood,ky
dbeez
