Water first or powder..?
Which is the correct way
  • Water First
    Votes: 5 31.3%
  • Powder First
    Votes: 11 68.8%
  • Total voters
    16
1/4 powder
10 mills water, mix until syrupy solution forms
10 mills 210 degree water, mix until slightly thiner
10 mills 214 degree water (superheat it) mix until slightly thiner.
add 1/2 power
add 60 mills 215 degree water.
Add .984763222 gallons 120 degree water
Add rest of power stir for 2.4 minutes
Add 4 cups of sugar and a pinch of salt
Stir 5.25 minutes until solution becomes absolutely delicious.
This is the most common method. Get a spoon and mix 2 parts of cocaine hydrochloride (regular cocaine) to 1 part baking soda in some water.
Heat solution gently (with a lighter or candle) until white precipitates form, and stop heating when precipitation stops.
After gentle heating, the freebase cocaine will float to the top, any excess soda will settle on the bottom.
Collect the compound that rises to the top, and you have the finished product, ready to use.
What you're trying to do is start and sustain a chemical reaction (bonding the hydrochloride with the base-soda) so as long as the reaction is happening you don't have to continue heating.
1/4 powder10 mills water, mix until syrupy solution forms
add 1/2 power
this needs to be a stickyyyyy
solidcrowd
solidcrowd
Buffalo, New York
AVSTANG02
