Want my comps to stop distorting
hatedonmostly
throwin' hunnits, hunnits
Head unit volume: from 0 to 33.
Comp amp gain: from 2.0 to 0.2v, set at 2.0v.
Sub amp gain: from 9.0 to 0.2v, set at 1.8v.
My comps are some average Pioneers that are pretty harsh but my ears don't mind it. I amp'd them a week ago, set the gain to ~1.8v to match the HU voltage. They would distort at around 25 volume on the HU because the crappy crossovers don't cancel out enough bass. I turned the gain down to 2.0 and it still distorts at 28 volume. The sub and sub amp can handle 30 volume without distorting, so I'm not getting everything out of my sub stage, which is disappointing.
Also, old school Sony amp doesn't have a high or low pass, just one knob for the gain. Head unit is not adjustable either. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
What should I do? What I was thinking...
-Get new crossovers that will cancel out more of the lower frequencies.
-Turn up the gain on the sub amp so the sub will be louder at a lower volume, and just turn it up to 27 or 28 to get the maximum performance out of my drivers, instead of 30.
If you woulda gotta HU with a lpf instead of getting one with **** colors you would be fine lol
//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif:laugh://content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Well at this rate I'd be better off buying a new amp, since if I do it won't have the ****ing power next to the ground on those ****ing gay *** screw in plate terminals
The Power bass and Clarion are the only 2 there that do rated. Id go with the PB. It has a lower SN ratio which will help. Only problem is it has a high THD. The Clarion has a lower SN ratio, but is CEA compliant, and has a wide range of LPF and HPF frequencies it can filter out.
hatedonmostly
hatedonmostly
Detroit, MI
hatedonmostly
