Kyle_Keating
Resonator
Ok so its like XBL^2 but a different approach... basically, I would lump them into the same category... dual/split gap. fundamentally they do the same thing... two gaps, one coil in between them... is that correct? MMAG might have the advantage of being more "semmetrical" (dividing up the flux properly.. i believe XBL^2 always has the problem that more flux lines migrate to the bottom gap) That really was not my focus, I was assuming perfect symmetry (ideal cases only) such that i could look at coupling efficiency only.It's an approach from STEP Technologies. Patrick Turnmire (from Red Rock Acoustics) is the CFO and Enrique Stiles is CEO. I think it's short for Multiple Magnetic Air Gaps. Pretty simple and intuitive: backplate/pole, magnet, steel plate, magnet, steel plate. Where Adire uses a rebate, they use another magnet. I remember they had a good idea where they used an aluminum basket between the middle plate and the magnet for the second gap where the basket would short out eddy currents and work well for thermal compression as well.
There are a few other ways too, I think the XBL^2 patent makes references to all of them.
