Wall Socket Sundown SA-12
sundownz
Pro Seller
Supporting Vendor
So... you want to know how much the SA-12 will take thermally ? Video starts at 14.5 amps (1740 watts) power drops off to the 1200 - 1400 watt range after the first 10 seconds and continues to play for a total of about 35 seconds at this power level.
Never going below DOUBLE rated power for the entire time on straight sine wave wall socket power @ 60 Hz. The woofer is NOT broken but I decided to stop as the current continued to drop indicating the coil was getting too hot. I plan to use this one in my Jeep so I didn't want it to go until it quit //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
http://www.sundownaudio.com/misc/SA-12_Production/Wall-Socket/CIMG2652.MOV
Fun stuff //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
This is a Dual-2 -- first sample that I built yesterday -- so nominal load was 4 ohms. I didn't use the Dual-4 (production) since it would be either 8 ohms (not much power) or 2 ohms (too much power).
looked like it was no big deal power wise on that sub. do 220v now!!!
*laughs*
I did just hook one up at 2 ohms... a Dual-4 model.
Played 19 seconds before failure.
Started at 3720 watts and dropped to 2472 right before failure.
I'll upload that video later.
Part II at 2 ohms this time !
Way too much power but we did it anyway! Played 19 seconds before failure at 400-600% over rated power. Started at 3720 watts and dropped to 2472 right before failure (multiply the current by 120 volts). Don't try this at home.
sundownz
Pro Seller
Supporting Vendor
sundownz
North Carolina
sundownz
