jacwood
I sent an email to TB speakers asking what a proper ported box would be
and they sent this back where can plug all this in to get an idea
thanks for any help
and this will be for TWO subs going in a expy
Box Properties
--Description--
Name:
Type: Vented Box
Shape: Prism, square
--Box Parameters--
Vb =20 liters
V(total) = 30.95 liters
Fb =39.66 Hz
QL =7
F3 =41.61 Hz
Fill =minimal
--Vents--
No. of Vents = 1
Vent shape = round
Vent ends = one flush
Dv =100 mm
Lv =680 mm
Driver Properties
--Description--
Name:
Type: Standard one-way driver
--Configuration--
No. of Drivers = 2
Mounting = Standard
Wiring = Series
Drivers sum coherently = Yes
--Mechanical Parameters--
Fs =30.3 Hz
Qms =3.7
Vas =20 liters [40]
Cms =0.291 mm/N [0.145]
Mms =94.83 g [189.7]
Rms =4.879 kg/s [9.758]
Xmax =12.1 mm
Xmech = 1.2 cm
P-Dia =167.4 mm [236.7]
Sd =220 sq.cm [440]
P-Vd =0.266 liters [0.532]
--Electrical Parameters--
Qes =0.3
Re =3.2 ohms [6.4]
Le =0.8 mH [1.6]
Z=70 ohms [140]
BL =13.88 Tm [27.75]
Pe =120 watts [240]
--Electromech. Parameters--
Qts =0.278
no =0.179 % [0.358]
1-W SPL = 84.72 dB [87.73]
2.83-V SPL = 88.7 dB [88.7]
thanks for any help
Box Properties
--Description--
Name:
Type: Vented Box
--Box Parameters--
Vb =20 liters
Fb =39.66 Hz
QL =7
F3 =41.61 Hz
Fill =minimal
--Vents--
No. of Vents = 1
Vent shape = round
Dv =100 mm
Lv =680 mm
Driver Properties
--Description--
Name:
--Configuration--
No. of Drivers = 2
Mounting = Standard
Wiring = Series
Fs =30.3 Hz
Qms =3.7
Vas =20 liters [40]
Xmax =12.1 mm
Xmech = 1.2 cm
Sd =220 sq.cm [440]
Qes =0.3
Re =3.2 ohms [6.4]
Le =0.8 mH [1.6]
Z=70 ohms [140]
Pe =120 watts [240]
Qts =0.278
no =0.179 % [0.358]
