w7 wiring...
1 SVC driver
It just doesn't get any easier than this: two terminals (+ and -) on the speaker, and two leads from the amp also conveniently labeled + and -. The rest is history.
3 Ohm Subwoofer: 3 Ohms
4 Ohm Subwoofer: 4 Ohms
8 Ohm Subwoofer: 8 Ohms
12 Ohm Subwoofer: 12 Ohms
Or is it that...
With negative from amp to negative from sub, and vice versa for positive
Well, is the sub a single voice coil sub or is it a dual?
If it is single then take the + on the sub to the + on the amp, same with the negative.
If it is a dual voice coil sub, then take the + on one side and connect it to the + on the other side of the sub with a wire. Then take another wire, shove it one of the same terminals and then send that one to the amp (do the same for the negative). That way will give you a 1.5ohm load, because if both voice coils are 3ohms, 3/2 is 1.5.
chris96camaro
Foreign and Domestic
chris96camaro
Charlotte, NC
RandyJ
