W7 or SI D2s?
corollapower
Hey
Trying to decide between the following:
1 JLW7 12" or 2 Stereointegrity D2 12"s
Thing is I could get the D2s for way less than the single W7 and I heard that the D2s aren't that far from the W7 sound?
Anycase scenario will be sealed box(es) and driven of a Kicker KX1200.1?
PS: Should I maybe look into RE xxx12s instead?
Woofer to woofer the W7 is a better overall driver, but a pair of SI D2s would definitely have more output, and should have less distortion overall, since they'd require about half the excursion (since there are 2 of them) for the same output level.
The XXXs are excellent drivers as well, IMO a closer match to the W7 than the D2s.
You definitely won't be able to get a pair of XXX 12s for less than a 12w7 though...
Have you considered maybe a single XXX 15 instead?
2 XXXs for around a 1000$s
the W7 for around 1100$s
and the 2 D2s will be around 750$ ca
Put I live in proly the most expensive country in europe too so..
And the W7 I can but here but the RE or SIs I would have to get shipped over from the US
ascendant audio avalanche 12's
http://www.ascendantaudio.com
the av12's will be available shortly. two of them should be able to match a W7 with no problem, sound way better, hit low notes better, and require the same, if not less watage and box space to do it.
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I loved my W7 pounds like no other but I did notice my KX1200.1 that I'm running right now really drains out my car. I would recomend a capacitor and a alternator upraged with that amp. I put in a 200 alternator and put in a cap for the subs
Ascendant ***** //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
NG
corollapower
corollapower
kvinnherad, Norway
macbethpoe
