w0's compared to Assassin?
Depends....whats your current box setup? If your going from two w0s sealed to two Assassins ported, that should be a nice difference //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
so what would be two subs that would be better than the wo's. i like the output they have but would like more sq. my budget it around 200-250.
The assasins should have alot more output thant the w0's. Much better driver.
seriously, the assasins are killer drivers, dont let there looks fool you! infact ive owned over 6 of them. and am currently building a 6cube@25Hz box for the 2 12's i just recieved. should be a killer setup(its even replacing my brahma!)
just because it doesnt have a 12 spoke basket/chrome motor does'nt mean its not a good sub...
I cant say anything about the assasins, but why not step up to the new W1's from JL.....if you liked the output of the WO's, you will love the W1's. Much improved sub......rubber surround, poly cone, larger voice coil and motor than the WO's.
Just an option...............//content.invisioncic.com/y282845/emoticons/veryhappy.gif.fec4fed33b4a1279cf10bdd45a039dae.gif
I would take the JLs for SQ and the Assassins for SQL.
Your budget is 200-250 for each sub? or in total?
If for each sub, then step up to the v3's. Wont be disappointed for SQ.
I figured total.....that is why I recommended the W1's. I paid $120 for mine.
Asssans, hands down. Better SQ and output.
Assasins are more compareable (but still likely better than) the W1v2 or W3. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Ummmmm..........how do yall figure this??? The W1 and W3 use better materials in the build.......poly cones vs paper.......blade terminals vs nickel plated push.......virtually the same power handling.......the only thing that looks clearly better about the assassin is the price. Everything else including the specs......hmmmm.....I dont know //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
So a fancy cone and terminal makes a sub? If you base your purchases off of that. I feel sorry for you. I geuss roadmaster subs are better than the assasins too because they use spun aluminum cones and nickeplated push terminals and similar rated power handling.
Also, read the post. w1v2 and w3
not w3v2 (which sounds like *** imo) or anything v3.
And it MAY be better than thoes (w3v2 and anything v3), But I dont have experence with them past hearing many installs with w3v2's. I have first hand experence with w0's, w1v2's, and w3's.
00maxima
00maxima
mass
mannyb18b
