vrx755vd no video image ?
i have a clarion vrx755vd i just hoocked it up and it playes dvds but i cant get any picture it says" only audio" i can hear it play but no picture maby somthing needs to be hocked up i only connected the speaker wires and powers i didnt touch any av cords i dont have a manual so any help would be great thanks
The pink wire has to go to ground but you need to put a switch in between the wire and the ground it usualy goes to the parking brake. But to use it anytime you need a switch and than ground the wire. Turn on the switch than turn it off than back on you can try this by just tapping the pink wire to ground than off ground than back on ground give about 2-3 seconds in between on and off.
Or if you just want to hook up something and forget about it get this.
http://cgi.ebay.com/CLARION-VIDEO-LOCKOUT-BYPASS-VRX745VD-VRX755VD-VRX765VD_W0QQitemZ350133990010QQcmdZViewItemQQimsxZ20081202?IMSfp=TL081202201008r31349
donovan_perro
donovan_perro
truro ,nova scotia
bigaudiofanatic
