VOM Question
AlterEgo99
Streaming consciousness
Well, I thought I new the basics of operating a voltmeter but a few terms have me confused and I am SURE someone can help. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
First, here is a direct quote:
"To check for a good ground reference, take a volt-ohm meter (VOM) and measure the resistance between the chassis of the radio and the shield of the RCA line level outputs of the radio. This reading should indicate a direct short."
How should I set my digital VOM to perform the above action?
Second, does anyone know what a "ground sniffer" is? Do you really need one or can a good ground point be determined simply from a VOM?
I'm attempting to troubleshoot an alternator whine problem and am going to be trying to determine the source step by step.
Thanks!
do you know how to set it for ohms? do that and touch the leads together. the reading you get ( 0.0 or close to it ) is the same reading you should get when you check for a good ground. ground sniffer is not needed your vom aka dmm is just fine.
Yup, I know how to set it for ohms. Any particular setting or does it matter the size of resistance? I'm assuming that once set I simply connect one lead to the ground wire and another to the chassis ground location and if it comes up all zeroes it is a good ground point. If it doesn't, then I should try some other location. Have I got that right?
Also, when checking the shield portion of the RCA line level outputs I am assuming this is the outer portion of the RCA jack?
Awesome, thanks man!
The infamous alternator whine is always such a fun thing to try and troubleshoot.
Oh yeah, one other quick question. I would like to check the speaker wires for any possible grounding short. I was planning on doing this from the amp location versus tearing the truck all apart, again. I take it that I can take the similar approach to test this using the VOM?
exactly, just test for continuity to ground //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif you know more than most so I am sure I dont have to explain that lolz.
if he measures resistance he will get coil resistance not speaker short to chassis.
OK, gettin' a bit confuzzed here...can you "simplify" what I need to do to test for a speaker short at the amp end? If I know what to set the VOM at and where to place the leads (and what to look for on the output) I should be good to go.
Thanks!
Never mind, think I've got it! //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
Set VOM/DMM to Ohms, place one lead on the positive (+) wire and the other lead on the negative (-) wire and observe the reading, which should be close to the ohm rating of the speaker. For example, for a 4 ohm speaker I should see something close to that number, say 3.55.
I'm curious what I will see when performing this on a component speaker where the wire from the amp runs to a crossover where the signal is split between the woofer and the tweeter. Should I still expect to see the rated ohms?
AlterEgo99
AlterEgo99
Domie Homie
AlterEgo99
