volume for RF HX2's
d audio 450
Registered User
i wanna make a sealed box for a pair of RF HX2 12's
i was wondering what i should have for volum ein the box....i was thinkin around 1.5ft3 or so....is this too much/too little?
also- i want to use 1" thick mdf- is this overkill?
thanks alot
-pat
Im not really to familar with the RF's, but about the 1" wood, yes that is overkill. You usually only need 1" when buildng BIG ported boxes that have lots of pressure going through them.
that should be a good size box for those subs. use 3/4 cuz ur hx2 subs shouldn't be running thousands of watts unless u have power series. if u have the punches the 3/4 should be good.
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
124
449
Factory. 2021 Chevy Silverado custom trailboss
679
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
902
d audio 450
Registered User
d audio 450
Pa Philly area
jbl_marshall21
    May 20, 2024
    May 20, 2024
