Volume/displacement question
  • 3
badboyzx2
I am going to build a box for my Shocker SS, 2.5 cubes after displacement tuned to 35. I know that you half to to add the speaker displacement, do I also have to add port displacement? For example (these numbers are all random), I want a 2.5 cube box. The speaker displaces .5 cube. Then I would need a to start with a 3 cube box, right? Then say there is .5 cube of port space. Would my total box size half to be 3.5 cubes then? Thanks for any help and sorry if this is confusing.
Originally posted by badboyzx2 I am going to build a box for my Shocker SS, 2.5 cubes after displacement tuned to 35. I know that you half to to add the speaker displacement, do I also have to add port displacement? For example (these numbers are all random), I want a 2.5 cube box. The speaker displaces .5 cube. Then I would need a to start with a 3 cube box, right? Then say there is .5 cube of port space. Would my total box size half to be 3.5 cubes then? Thanks for any help and sorry if this is confusing.
Yes you need to account for speaker displacement and port displacement.
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
94
what ^ said. amp gain setting info, test tones are at the very bottom...
405
Factory. 2021 Chevy Silverado custom trailboss
9
556
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
868
Yes, the power wires' colors don't match from the dash to the new harness. However, I tested them and the wire I'm treating as the constant 12v is...
9
badboyzx2
badboyzx2
grand rapids, MI
badboyzx2
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
