T tjjohnson91 10+ year member CarAudio.com Elite 610 1 welcome mn Mar 6, 2010 #1 is this bad? Click to read more...
MmatsDude 10+ year member CarAudio.com Veteran 4,162 1 Los Angeles CA Mar 6, 2010 #2 nope just dont let it frop under 12 volts
OP T tjjohnson91 10+ year member CarAudio.com Elite 610 1 welcome mn Mar 6, 2010 Thread Starter #3 thats driving down the road.................. i have 110amp alt and 120ah battery and starting battery
supermaxx123 10+ year member CarAudio.com Elite 1,856 8 I.E. Mar 6, 2010 #4 your alternator won't last long, good thing you have those 2 batteries.
D DammitJames 10+ year member CarAudio.com Elite 627 12 El Dorado, AR Mar 6, 2010 #5 is this bad? Click to expand... 12.5 volts isnt bad for your amp but on the other hand this will make your alt work like crazy. the lower your voltage drop the harder the alt will work to try and keep it at 14v. your alt will work itself to death thats the bad part
RAM_Designs 5,000+ posts SketchUp Master 21,735 362 Rockwall, TX Mar 6, 2010 #6 Where does your voltage sit at without the system playing?
outsideshot23 10+ year member CarAudio.com Veteran 3,745 62 OKC Mar 6, 2010 #7 Its a strain.. It will work but over the long haul ytour alt will go bad... You need to get it rebuilt or get a bigger one.....
n2audio 5,000+ posts OPTIDRIVEN 5,690 86 Lawrence, KS Mar 7, 2010 #8 after you're blasting it for a while pop the hood and grab the alternator. you may want to have your nearest burn unit on speed dial. Heat kills -- your alt's on borrowed time.
