volt meter
I like the stinger ones. But sonicelectronix also has some that would work probably just as good. On my stinger i had three wires, neg, remote and pos. Its pretty self explanatory. I just hooked the remote turn on to my deck and then negative to my deck then ran the positive to the amplifier positive because thats where you want the volts to be read. With the stinger you have to manually adjust it because it wont be accurate if you just plug it in. I just used a dmm, took the cover off and turned the knob on the volt meter until it matched my dmm. Its really easy.
STINGER SVMB VOLTMETER BLUE 3-DIGIT DIGITAL DISPLAY NEW | eBay
ok that's simple, for some reason i thought they were alot harder to set up and more expensive. What if i have an amp for my mids and my sub then what amp would i hook it up to, sub amp right?
Hmm, do they make universal gauge pods that would fit in my jeep? I wonder if I could get a dual for the drivers side to hold a volt meter and tweeter and a single for the right.
I like the stinger ones. But sonicelectronix also has some that would work probably just as good. On my stinger i had three wires, neg, remote and pos. Its pretty self explanatory. I just hooked the remote turn on to my deck and then negative to my deck then ran the positive to the amplifier positive because thats where you want the volts to be read. With the stinger you have to manually adjust it because it wont be accurate if you just plug it in. I just used a dmm, took the cover off and turned the knob on the volt meter until it matched my dmm. Its really easy. STINGER SVMB VOLTMETER BLUE 3-DIGIT DIGITAL DISPLAY NEW | eBay
I will most likely get this one. Now you said i have to manually set it, do i set it with my vehicle on or off?
Ill be wiring my next one up at the amps battery bank area and run it to the dash to keep an eye on it
im not looking to seal off im trying to stay out of wall classes and plan on staying in trunk classes
15
Thanks all for your responses! In regards to the dB meter suggestions, I ended up using my Blue Yeti microphone which supposedly can handle up to...
BNolan12
BNolan12
Lafayette, LA
Kangaroux
    Jun 1, 2024
    May 31, 2024
