voice coils
you didnt answer my question when I said to post your application, here I will make it easier for you this way.
If you plan to use 0-1500wrms go copper
If you plan to use 1500-3000wrms go to aluminum
If you plan to go higher, well... you wouldnt have asked these questions lol
im just playing with ya but for real, id just say go copper assuming your not burping the crap outta these subs for comps.
just everday listening on about 2200 watts 6cubes tuned to 38 hertz
Easy question. the only advantages aluminum has over copper are:
1: aluminum is more pliable.
2: aluminum is less expensive.
3: aluminum lighter.
The last advantage doesn't really matter much because of the relatively small volume of material used in any application.
so if Afro-engineering is your cup-o-tea, go aluminum.
Do it right, go copper.
What something ridiculously expensive that makes heads turn but works amazingly, SILVER! but then again good luck getting people to believe your VC's are solid silver. //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
ummmmm copper!
You would be surprised how much difference it is when you are trying to juggle different parameters.
And like Mr. Sundown said, it varies on the design goals.
Lowthers use solid silver coils //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Fosgate1
Fosgate1
williamstown,ky
lincolntc690
