ok so im buying 2 w6's which i will wire parallel to give me 2 ohms each. If i wire these both to a mono amp, specifically the PA a3000db, will it produce a 2 ohm load or do the ohms change with the 2 subs hooked up.
if they are both dual 4 ohm, the 2 subs combined will give you a 1 ohm load. if you can wire each sub to 2 ohms, that means they are indeed dual 4 ohm, so the 2 will equal a 1 ohm final load.
