viper d2500.1
pwnt by pat
Pat for Prez 2024 - vote!
Okay, still thinking about our class a(or b now) vehicle and have a couple questions...
First, the viper 2500 does 2500w@2 ohms. Is it 1 ohm stable (or less) for burps and what kind of power would we be looking at?
Second, is the amp strappable? It says it has different gain matching or something along those lines but what does that mean?
And if that’s not enough, you can double, triple, and quadruple that power by adding more d2500.1 using our built-in synced gain feature
Finally, how do DBDrags rules for running two amps strapped work? Could I use one amp per vc of a dvc 2 and have that pass under strapping as long as the input of the second is set to the output of the first?
one more question //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif The d1200.1's - if you strap two together (1200w@1 each) and run at one ohm bridged - if stable for burps, what kind of power would you be looking at?
From what i have read, power with the Vipers usually doubles, although minimum imp. rises. The 1200.1's can be strapped for 2400@2ohms, but are no longer 1ohm stable.
pwnt by pat
pwnt by pat
Pa
pwnt by pat
