soooo the 1100 is an 1100 and the 1500 could be an 1100 but they put 1500 on it because the 1100 was a 04 and the 1500 was an 05? so its possible that the amps dont differ at all and the 04 1100 may not put out less power then the 05 1500? oh well..im still getting a 1500...for 155 rather then an 1100 for 165I dont believe the 1500d's have ever been tested and proven to put out more than a 1200.1 or a 1100d, just a different model name for a different year.
Go for it, Im not up to date on every detail of the amps so I cant answer. Either way though, I think that you will be happy.soooo the 1100 is an 1100 and the 1500 could be an 1100 but they put 1500 on it because the 1100 was a 04 and the 1500 was an 05? so its possible that the amps dont differ at all and the 04 1100 may not put out less power then the 05 1500? oh well..im still getting a 1500...for 155 rather then an 1100 for 165
i use my remote dial on almost every track, every cd i have ever heard is produced slightly differently, some a little more bass some a little less, track comes on - a quick tweak, and the bass is set to be deliverd the way i want it:yumyum: ...every track.It comes in handy more than you would think, unless you are always in the mood to listen to a system with a lot of bass or always are satisfied with the bass you have or unless your system is perfectly matched to every single song you listen to with change required.
Exactly why I liked it and used it daily //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gifi use my remote dial on almost every track, every cd i have ever heard is produced slightly differently, some a little more bass some a little less, track comes on - a quick tweak, and the bass is set to be deliverd the way i want it:yumyum: ...every track.
i used mine when i had it...but my radio has sub volume also.so i found it not needed.i use my remote dial on almost every track, every cd i have ever heard is produced slightly differently, some a little more bass some a little less, track comes on - a quick tweak, and the bass is set to be deliverd the way i want it:yumyum: ...every track.
The thing is, I believe the sub controls on the head units are actually bass boosting functions that work only at a certain frequency. You should look into that before using it any more.i used mine when i had it...but my radio has sub volume also.so i found it not needed.
