Verify these numbers ...
oc_cheby
Hey everyone … I’m going to build my first sealed enclosure that will be going under the back seat of a 06 Silverado Ext Cab to house one Power Reference 10" Dual Voice Coil Sub. The sub has a mounting depth of 5”.
I’ve drawn it up in Sketchup but I wanted to run it by you guys to double check it. The spec sheet for the sub says … 0.65/0.82 (Min/Opt). I used the Volume Calculator from 12volt.com, it came up with 0.68631. I’ve included a few pics that will hopefully help.
Thanks in advance.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
10" Sealed Sub Box
Volume Calculator
Here is what the entire box that will go under the back seat will look like ... hopefully //content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif
Thanks for your input everyone. So I should be good to go if I just add some polyfill? Do you think the amp would get too hot in that space? should I give it more ventilation? //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif The amp and storage space will be covered with a lid.
oc_cheby
oc_cheby
Dallas
oc_cheby
