I have a 2006 Nissan x Terra. When I bought it, it already had all the wiring set up to install a stereo and the(sub-woofer/ bass speakers), but it was missing those components (it still had the speakers that came with it, just no stereo to control them). So I got a stereo and installed it fine. I've been using it for months with no problem. The my friend got a 200w amp (for a sub-woofer) from another friend. Because he already had a 1000w amp in his track, he gave it to me.
He checked the wiring and made sure it was set up correctly, then installed the amp. We tested it with his 1200W sub-woofers and played music for a few hours, and it worked fine. Then we unplugged his sub-woofers and put them back in his truck. 8 or 9 hours later I got in my vehicle to go home, but I noticed that the back-lights for the gas gauge, speedometer, temperature gauge, and another gauge, as well as the back-light for the gear stick thing would not come on. My friend said it was probably just blown fuse, so I went home (~20 min. drive).
I turned the vehicle off, but left the headlights on because I would be right back. I got back in less than 3 minutes and the entire vehicle was filled with smoke. The first place I thought to look was the amp; no smoke coming from there. While I searched for the source, my brother unhooked the battery. I finally found smoke coming from the fuse box.
The smoke wasn't coming from the little fuse board itself and none of the fuses were blown. I think the smoke was coming from a bunch of wires that were bound together with electrical tape, but I can't be sure. I just know that smoke was coming from the compartment that housed the fuses.
Is there a reason that installing an amplifier could be as dangerous as to almost cause an electrical fire?
