Various Alignment Info
This how I do it, right here.
EBS - 4th Order Large Vented Enclosure with Low Tuning
Basic Theory
EBS- Extended Bass Shelf. This is only one of the various different types of vented alignments which are possible and follows many of the same characteristics of vented enclosures. The idea is to intentionally design the enclosure to be 125-175% larger than the optimal calculated volume and then tune the enclosure much lower than optimal as well. The result is a significant amount of extended low frequency response. When the response curve is simulated, a visible "shelf" can be seen in the curve just above the tuning frequency before it sharply rolls off. The LEAP manual explains EBS theory like this: "The name [EBS] was derived simply from the visible appearance of the response curve. The bass response is extended to a lower frequency than would be possible from the QB3 alignment, but at a lower level or shelf relative to the mid band level. Although the EBS alignment is not a nice neat flat alignment such as the QB3, it is very often a much better choice than the QB3. The EBS alignment has some interesting features. Consider a loudspeaker with a Qts of 0.30, the QB3 alignment would have about 2dB more output at a frequency of twice the Fs, while the EBS alignment would have over 2db more output at Fs. In most cases the EBS alignments will have far more subjective [low] bass than the QB3 alignments. Also, if you were to equalize the responses flat to Fs, 10db more boost would be required for the QB3 versus the EBS. This can dramatically consume large amounts of headroom in the power amplifier, and may also far exceed the linear excursion limits of the speaker. The EBS alignment will maintain much lower cone excursion at frequencies near Fb than is possible with the QB3 alignment. This can be very important for high power systems." Advantages
Extended low frequency response down into the teens. Subsonic, earth-shattering bass response. Increased efficiency at the lower frequencies (below ~25 Hz) but decreased efficiency at higher frequencies (above ~30 Hz) depending on tuning and box volume. This is a rough figure since many different combinations can be designed to yield specific results. In general, low frequency is extended and efficiency increased at the expense of reduced efficiency at higher frequencies - all within the generally accepted range known as bass. Disadvantages
The enclosure size is huge. Anywhere from 5-15 cubic feet depending on the size of the driver being used. Power handling capability of driver is reduced anywhere from 25-50%. Driver may reach Xmax sooner above fB even if it never reaches Xmax right at or below fB. Lack of real presence, lack of kick or punch, may be subjective terms uses to describe EBS alignments. The overall impact of the bass is much softer. Signals between 40 and 60 Hz are reduced. Harder to "sell" because most people are more receiving to a pronounced upper bass response rather than an incredibly low and deep bass response . It takes 8 times as much power (as well as moving air) to make 20 Hz sound as loud as 40 Hz. Best Applications
Where the truly deepest of all heavenly deep bass is desired. For drivers with a large Xmax and the ability to consume large amounts of power. For drivers whose T/S parameters dictate an optimal enclosure size that's smaller than what the designer wants to build. Large Home Theaters and varying kinds of music with heavy bass tracks would take the best advantage of this enclosure alignment. Where size is no concern and sub-20 Hz bass is the main goal. Bragging rights.
ciaonzo
TheContinental
ciaonzo
WI
ciaonzo
