usx2100 for powerbase 15's
TIGERFOR2
My little brother just put two powerbase 15's in his trooper. They are rated at 300rms and are single voice coil 4 ohm. Will this amp work? I dont know the cf of his box though.
2-Channel Amp Specifications
Amplifier Type: 2-channel
RMS Power: 100W x 2 @ 12.9V
Bridged RMS Power: 300W x 1 @ 12.9V
THD at Rated RMS Power:
Speaker Level Inputs: Yes
Preamp Outputs: Yes
Built-In Crossovers: HP/LP
Bass Boost: 0-18 dB
Frequency Response: 10-30,000 Hz
Channel Separation: 90 dB
Signal to Noise Ratio: 103 dB
Fuse Rating: 2 x 20 amps
if i m not mistaken the 2100 puts 300 @ 4ohms bridged. with 2 svc 4 ohm u can only get 2ohms or 8ohms. dat being the case u would only be sending either 100rms to each, which dotn think would be enough.
get something that puts at least 500rms @ 2ohms, n u should be happy.
an example is the memphis st500d or mc500d, dunno anything else from teh top of my head. oops, USX800D should be nice too.
TIGERFOR2
TIGERFOR2
ALBANY,NY
Matador
