Grim
Resident Electrician
I searched but didnt find everything I needed...
Im using the highest end dremel they offer.
I have the cutting bits(like the ones for the rotozip). I bought those because I remembered the old infomercials. But after looking some more I found Router Bits for the dremel.
I have the attachment that allows me to use it as a router with adj depth from 1/4 to 1in...
So my question is..Should I use these to cut circles, or buy a 1/8 or 1/4 Straight router bit...
Also I know with the router bits, to do 3-5 passes on 3/4in MDF. If I use the cutting bit can go I go all the way through or should I do a few passes with that as well...
Im going to use it for carpeting as well...I have an idea similar to the one used in the Carpet tutorial on here, so I would need to be able to make a 2.8in slot...would the Cutting bit be ok for that?
