Use All Outputs??
if u can wire the speakers to 2ohm and only wanna use 2 channels thas fine, im currently running a 4ch but only using the 2 front channels the rears are unused
Well are you powering speakers or subs? if speakers, you should bridge them (one bridged channel per speaker) Just keep the gains down. If its subs, it all depends on the vc config of it.
hey guys i have a 4 channel amp running 4 speaker each @ 4 ohms... the amp runs 40x4@4 and 80x4@2... is there any way to wire these speaker to get the 2 ohm load per speaker?? can i just buy 4 ohm resistors and make them act like a speaker to wire in parallel and get the 2 ohms load?? any other ideas??
The reason you don't want to use a 4ohm resistor is because it's only a 1/4w most likely and chances are you want to run more then a quarter watt to your speakers..
No.
Sure, but resistors don't make sound, just heat.
any other ideas??
Add more speakers.
You could do this, but you will not get any benefit from it. Here's why:
The amp will see a 2 ohm load and will produce 80watts per channel, but that power will be split between the loads on that circuit. In the case you mentioned the speaker would get 40 watts (no improvement over running it at 4 ohms) and the resistor will be turning 40 watts into heat. Basically you will be heating up the amp and the resistor for no benefit.
If you have four speakers to run, run each speaker on its own channel of the 4 channel amp. That's the most power you will be able to get to your 4 ohm speakers from that amp.
if i try to bridge 'em... the amp will just shut off if it's not right, right?? nothing will burn up or anything will it??
Well theoretically yes, but FYI that doesn't always happen, i had a legacy 1000wmax amp and i ran it bridged in 2Ohm and i blew a MOSFET and had to replace it. (lasted bridged at 2Ohm for about 3minutes.)
Mixophrenia
Mixophrenia
Columbus, OH
Mixophrenia
BP1Fanatic
BP1Fanatic
