Use 1 amp or 2 for this system?
tracyrick
Limited035
SQ system.
MB QUART QSC216 6.5" = 150 Watts RMS each speaker (300 total)
JL Audio 12W6V2 = 400 Watts RMS (500 would be nice)
1st thought - hit this with a JL 300/4 for the fronts and a JL 500/1 for the sub
2nd thought - is there a clean way to power this system with only one amp?
Not sure what amp would do that well...would save me some $ and space maybe.
yes, there are one amp options out there. u will need a 4 channel amp, a strong one. it would assumably do 200x4 @ 4 ohms, then u can bridge the rear two channels to the sub for the 400 @ 2 ohms if its a dvc 4 ohm sub. so there are options out there for that, but i would personally jsut do two amps.
If you bridge a 2/4 channel amp most of the time it will be at a 4 ohm load, not 2ohms.
umm.. what? :fyi:bridging his rear channels to a dvc 4 ohm sub would be a 2 ohm sub //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
He was trying to explain that most 2/4 channel amplifiera are not 2 ohm stable when bridged...
There are many 5 channel amplifiers out there that will suit your needs, just depends on what you want to spend..
tracyrick
Limited035
tracyrick
Longmont, Colorado
yacob.naif
