I have a used usa spec ipod addaptor for a 2003 and up accord If you want to keep your factory stereo and add an ipod this is the way to go i used this for about 3 months paid 149 for it will take $75 for it
You can take it with you. Just because you have a factory radio in your Honda, doesn't mean you have to leave your iPod at home. Just install USA SPEC's Honda PA11 iPod interface — it lets you listen to your iPod tunes through your car's speakers, and to control song and playlist selections right from your radio.
Just mount the compact interface box in a hidden location in your vehicle, and connect the included adapter cable to the CD changer input on your compatible 2003-up Honda/Acura factory radio. Plug your iPod into the interface and you can control and charge your iPod while you drive.
Read More
The PA11 adapter features two different playlist options: create up to five mobile playlists and use the vehicle's CD changer controls to access them, or use the "Direct" mode to select your playlist with the iPod's controls. Either way, you'll always have full control of all iPod functions, including random or shuffle play. The interface also provides an additional auxiliary input so you can connect other devices as well.
Please enter your vehicle information or call a Sales Advisor at 1-888-955-6000 to find out if this adapter is compatible with your vehicle. The iPod interface uses the CD changer port, so any existing changer that you have must be disconnected.
Details:
iPod connection adapter for select 2003-up Honda factory stereos
manage the iPod via your radio's CD changer controls
adjust volume, track up/down, fast-forward/reverse
use up to five playlists (select five favorites, or Auto Playlist will let you choose from the first five on your iPod)
Direct Mode lets you control everything via the iPod itself, giving you access to all playlists (requires a DIP switch change on the USA SPEC adapter)
auto memory locates last song accessed on each playlist
compatible with all iPod and iPod mini models equipped with a dock connector and iPod software update 2004-04-28, or higher
warranty: 1 year
Read More
Details:
warranty: 1 year
