*urgent* 1997 Camaro install help
if its anything like a 94 no. u have to pull the panel under the steering wheel and take down your glove box you will see the screws/bolts i belive there 7 or 8 mm very easy,
if you need to get the the stereo you have to take off the panel under the steering wheel, then there are 2 bolts under that, 3 along the left side of the glove box after you open it up then the trim piece pops out. thats how it was in my friends '95 last week
i miss my camaro //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif no proub man i had mine apart so many times i bet i could do it blindfolded ....
its not the entire dash is a small peice on the left under the wheel and jsut open the glove box push up on the arm that the glove box lid is attached with and the lid will flop all the way open then take out the screws and the center will jsut come off then. its how almsot all the gm cars work far as i know my sunfire is the exact same way too.
Funny. I got a 1997 Pontiac Firebird and all I have to do is pop the panel around the stereo off and unscrew 4 screws and WALLA!! I knew I chose a Firebird for something.
i jsut want you all to see something....
you can jsut remove the trim piece to access the stereo
this concludes todays lesson
sanmarcosZfreak
AE Installer
sanmarcosZfreak
Kissimmee FL
sanmarcosZfreak
ThxOne
    May 13, 2026
