Ok I upgraded the big3 cause I had slight dimming.
I did it with 4 gauge, I know I will have to go bigger now, but at least I know how easy it is to do.
Anyway, I added a wire to the alt to battery using the existing stock distro. block (I guess that's what it is) that the original wire is going to, I plan on fusing it separately with an anl inline (will this help?)
I added to the ground wire and engine to chassis.
In addition to the big three Ive recently built a new enclosure for my 2 e10o's that are being pushed by a tsunami 1800 (
The subs are in about .5 cubes each and they sound awsome and hit hard. I did adjust the gains to corespond to the enclosure size (increase a little) but now my lights dim even worse than before.
It's a 2002 supercrew, 130a alt.
Im also running the tsunami 4440 for components
Let me reply to my own thead,
1.Turn your gains back down that little bit
2.Upgrade your "upgrade" to 1/0 wire
3. TURN DOWN THE VOLUME (yea right)
4. Maybe run thicker than 4 gauge to the amp??? Im petty sure that's what it will accept.
Any other Help would be appreciated......
